65 f100 + 1995 mark viii
Re: 65 f100 + 1995 mark viii
It's looking good! I like the stance.
therealjoeshmoe
Post by therealjoeshmoe »
looks real nice!!!!!
Image Image Image Image
65styleside
Post by 65styleside »
Been awhile on the updates but I'm still plugging away.
Vintage air unit hooked up(heat side anyway), easy system to install, very straight forward.
2 speed wiper motor with delay, in and working. Waiting on some new linkage though, my bushings ate pretty shot.
Put on rear air shocks, the ones team321 recommended for the mark viii rear clip where way to squishy. Now I can haul stuff without squashing the rear.
Electric fan in and hooked up, nice and cool.
Still no digital gauges, money, money.
Seat belts in.
Put a few hundred miles on, runs good. I ran a 14.6 quarter mile, fast enough for a 50 year old body I guess.
I'll get some pics up soon.
rooster91
Post by rooster91 »
nice truck! can you snap some interior pics next time?
If it wears make up or has wheels and a motor i want to play with it!
jamesdfo
Post by jamesdfo »
Well, apparently I've been asleep in the keyboard, because I totally missed this thread!
And I gotta say, I like it!! I would totally drive the wheels off that truck!
Nice work!!
Cheers!
James
65styleside
Thanks for the positive feedback, I really love it. Blast to drive. Can't park anywhere without somebody wanting to talk about it or take pics.
Here's the dakota digital gauges, pricey but a super simple install
Image[/url]
Image[/url]Image
My heat and ac temp controls
Got a million questions! With the rake you have on the truck, do you happen to remember the pinion angle? Did you stay with the MKVIII pattern on the rear wheels? What did you end up with for fuel tank?
Thanks for any help!
65styleside
I don't remember an exact degree, I will be under it next week, I'll check it for you.
I got some adapters off ebay for the rear too. I intend to have them re drilled when I take the bed back off to box the rear frame.
I got here is a link for the tank I used. I have some pics of it somewhere. They told me the large center baffle would be enough to control fuel slosh.....it is not. Under 1/2 tank the fuel pump starves under hard accel and cornering. I have a walbro external pump, I'm going to add a surge tank to remedy this problem.
http://www.tanksinc.com/index.cfm/page/ ... /prd45.htm
65styleside
I passed the filler neck through the frame, the filler itself is on the back of the passenger wheel well inside the bed.
That's a piece or 4" x6" x 5/16" angle iron I used on the rear of the frame. It acts as a cross member and I will weld a reciever to it. I will also make a removable liscence plate that mounts into the reciever hitch, basically hiding the hitch behind the plate.
65styleside
I finished my headliner, what a pain in the butt all alone. It came out pretty good. I cut it outta frp from lowes, covered it with foam headliner material and then wrapped it in some stuff called trexx, all from Joanns.
Price: 33 frp, 15 foam, 20 trexx, 30 spray adhesive. 95 is a lot better than 280 from lmc and I think it looks better.
I'm done with the pattern, pm me if you want it, you just pay for the ride.
Those screws look jacked up but they are lined up, must just be the angle.
Pack Rat
Post by Pack Rat »
Looks great.
1966 F100 240 3speed
Danimal
Post by Danimal »
Looks great, I like the rima too
The weathers here, wish you were beautiful.
Danimal
Post by Danimal »
Looks great, I like the rims too
Ratrod_Rhysie
Post by Ratrod_Rhysie »
this effy is effin bangin. did you notch the chassis to accept the jag ifs or is it sitting on top of the set up?
orangeRcode
Post by orangeRcode »
Nice looking truck. Alot of quality workmanship!
I like the paint booth you built. Did you have any filters in the fans? How did you keep the bugs and other flying debris out of the paint?
65styleside
Ratrod_Rhysie wrote:this effy is effin bangin. did you notch the chassis to accept the jag ifs or is it sitting on top of the set up?
I sectioned it into the frame. Don't remember exactly how much off hand, 1.5 or 2 inches seems to come to mind. Just kept going till I liked the ride height.
65styleside
orangeRcode wrote:Nice looking truck. Alot of quality workmanship!
I put filters on the intake side of the four intake fans and about eight filters on the exhaust openings(no fans on the exhaust openings).
If I had to spray another car or truck I would put as many fans as I could find in the frame. Probably try eight intake fans and 16 exhaust openings. I used the el cheapo fans from lowes, got them on clearance for 12.00 each. Filters where the bulk cheap filters from lowes also. Like 2.00 each.
The booth just did not clear as fast as I wanted, it works fine for painting bikes but not cars or trucks. I'm hoping to build a permanent paint booth in an outbuilding for future jobs.
