auto tranny ?
Posted: August 23, 2006, 9:11 pm
by Charlie64
Is the ouput shaft on the back of an auto suppossed to be moved up/down left/right? It's the shaft that the driveshaft yoke slides over. I have a wierd vibration too. It'll actually clunk if i really try to move it. This is bad, right? :cry: Internal tranny problems?
Posted: August 23, 2006, 9:24 pm
by MadMaxetc
Ya, there sould be no play like that
what type is it? FMX, C4 C5 C6??
Posted: August 24, 2006, 8:20 am
by FORDBOYpete
Actually the type where the yoke slips over the end of the output shaft and into the tail housing seal & bushing will have play, up to .125" in fact.
The slip joint & tail housing bushing carry the end of the output shaft to a great extent. :roll:
4 bolt flange type yokes, where slip joint bolts up to the back of tranny at the output shaft should have no "lateral" play, yet slip fit together & rotate easily without resistance. . . . .
So the answer should be some play id within tolerance on the slip in style yokes but not the bolt up type.
FBp 8)
Posted: August 24, 2006, 7:11 pm
by Charlie64
sorry guys. it's in my dad's 93 f-150. it' s a slide in style not a bolt in. hmm now i'm confused. I thought for sure that was it as my 64 doesn't have any play. Thanx for the info guys Hopefully i can get this fixed up so I can get working on the 64 again.
