GONNA START ON THE REAR TONIGHT
- therealjoeshmoe
ANYONE KNOW HOW TO TELL WHAT GEAR RATIO YOUR REAR END IS?
Re: GONNA START ON THE REAR TONIGHT
If you have the driveshaft disconnected, you can just jack up the rear axle and measure the number of revolutions of the wheel per full revolution of the rear axle yoke. 3 3/4 = 3.73, 3 1/2 = 3.5, 3 1/4 = 3.25, and so on.
There's also info on the driver's door warranty tag pertaining to rear axle ratio. Should be the last set of numbers on the second line (after AXLE). You can decode it here: http://home.earthlink.net/~threynolds2/ ... s6166.html
1966 F-100 longbed - Project Betsy
- therealjoeshmoe
WELL MY PUMPKIN CAME OUT OF A LINCOLN CONTINENTAL AND MY AXLE IS COMPLETELY OUT OF MY TRUCK
- bobenhotep
If the differential is sitting on the floor, draw a mark on the ring gear, and a mark on the yoke. Rotate the yoke and count how many turns it takes for the ring gear to turn once.
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
"The Iron Rhino"
-duraspark II/ HEI
- Blackwaterforge
divide teeth on ring by teeth on pinion.
- therealjoeshmoe
OK I WILL TRY IT TONIGHT AND REPORT BACK LOL
THANKS
THANKS
Joey, you KNOW we were gonna make you do some math at some point in time !
Hunter's 64
Ring gear should have the ratio stamped into the outer edge
Danny
Danny
- therealjoeshmoe
lol ok so i tried, i dont guess it really matters what gear ratio to me.. idk why i was even asking..lolfoodstick wrote:Joey, you KNOW we were gonna make you do some math at some point in time !
- therealjoeshmoe
its really that easy?? lol i will look and see tonightHunter's 64 wrote:Ring gear should have the ratio stamped into the outer edge
Danny
thanks
