Valve cover
roygar
Valve cover
Post by roygar »
I began work on my 62 Uni this summer. With oil oozing from under the valve cover I knew I needed to replace the gasket. I found it odd the former owner chose not to use any bolts on the cover, just gasket glue. I popped off the cover to find no bolt holes for the cover. I looked at Chilton and realized my 223 uses a cover with two bolts on top connected to the rockerarm supports. However, it appears my rockerarm supports are not threaded for a stud bolt. I could tap the supports easily since there is already a 1/4" hole. So, I'm looking for the correct rockerarm cover for a 223. Please help. I can't find the part, except for a $150 aluminum cover.
Roy
jeepbut
Post by jeepbut »
Welcome Roy. I see you found us. He might have gotten here sooner if I had given him the correct web page. Please post a picture of your truck. It's a short uni, Lyman green, 223, four speed granny- really neat truck. I am not familiar with the 223, but I am sure someone would have the tapped rocker arms and the valve cover you need for cheap from a blown or worn out 223. I wonfer if the rocker arms you have are from a car 223 and maybe the car valve covers attached differently. Roy grew up southwest of Kansas City, so I suspect we will see him at Slickstock 08. Somebody jump in and help out this new member. I really enjoyed meeting you and getting to see your truck up close (I had been staulking it for 4 months!). Thanks, Lyman.
Max
Post by Max »
Welcome to the club Roy! Our Corpus Christi Slick Squadron just doubled.
66fordtrucknut
Post by 66fordtrucknut »
Welcome from Md. Roy. What is the casting # on the head. I know the late 50's 223's had the 2 bolts valve covers, My 62 has has the newr style don't know about the 61's, I'll keep my eye out for one, A guy down the street hada 223 out of a 59' that had 2 bolt vc.
Charlie
62' SWB uni 223
66' F-100 Short/wide 352
78' F-350 dually dumpbed 400
12' F-150 5.0 3:73 LS
fmartin_gila
Post by fmartin_gila »
Sounds like someone had to replace the head, and did so with the earlier one. I would think the easiest way would be to get a valve cover gasket set for the earlier 223( should have the perimeter gasket and the sealing rings for the two studs in it). Make two holes in the cover in the proper place and mount it. I think the changover was 59=early - 60=late.
Fred
fmartin_gila
Thinking about this a little more, I believe the 215 would be the same cover, so if junkyarding, any cover from the 50s should work.
Fred
Truckfarmer
Post by Truckfarmer »
I have an extra valve cover for sale. Email me.
roygar
Post by roygar »
Thanks for the warm welcome. I agree with fmartin, the Kansas farmer probably replaced the head from an earlier engine. I know it had been overhauled and had only 20k on the engine. I have not been able to find the casting # on the head yet. Where is it located? I found info on the 223 online-the 54-59 used 2 bolts on the valve cover, the 60-64(5) used 8 bolts. I don't want to drill two holes on top of the 8 bolt cover because I'll have to plug all the bolt holes in the cover since they are open to the inside of the rocker arm space. I'll give truckfarmer a try.
Roy
The Big M
Post by The Big M »
Welcome!
I agree, don't drill the 8-bolt cover. Get yourself a 2-bolt one. They look much better, imo... :)
:welcome: Roy.
Glued on you say :shock: .
Alan
MrEvil
Post by MrEvil »
Yeah, the 223 that came out of my '61 has the 8 bolt cover. Not 100% sure it's the original engine or not.
Vehicles:
2000 F250 Superduty Crew cab
1998 Ford Crown Victoria Police Interceptor(work beater)
1961 F100 Uni (my baby)
1966 Thunderbird: someday.
ripsnorter
Post by ripsnorter »
I've got a '62 F100, (not a uni) with a 223 in it. I'm 90% certain its the original motor and it uses the normal 8-bolt flange mount valve cover. (although in my head I'm thinking it has more like 6 bolts, I'd have to look though)
Sounds indeed like you have an older head on it.
jeepbut
Post by jeepbut »
Roy, I might stop by and take a couple of pictures of the uni and post them here if that is ok. Thanks, Lyman.
