cab mounts
cab mounts
Can anyone help me with deminsions for 1961 cab mounts?I know you can purchase them . However I dont see why I couldent make them.I am having to make so much of the rest of the cab that is not avalable I figured why not save the cash.My truck was and is so badly ravaged by northen salt I dont have much to go on.The cab mounts appear very simple I would just like some starting deminsions.
One of our members made his own cab mounts & also improved them over the factory style, to not trap dirt & moisture.
Hopefully he'll come along with pics soon.
Welcome to the site!
- 66fordtrucknut
I made my own mounts but unfortunately they're for a 65-66 cab, 61 - 64 are completely different. I made mine out out 11 guage steel. shame yours is so far gone. I take that your need floor pans too. Maybe you keep the back bolts in, cut out your old mounts, jack up the front if you need and just improvise some new mounts, I made templates out of thin cardboard, they only have to connect the floor to the frame. I would think they would be easier than the 65-66 mounts. BTW welcome to the club.
Charlie
[albumimg]1130[/albumimg]
Charlie
62' SWB uni 223
66' F-100 Short/wide 352
78' F-350 dually dumpbed 400
12' F-150 5.0 3:73 LS
thanks .That is actually the way I am planing on building them. I am unsure of the distance from the frame to cab. And for the record they are completly gone. carrosion got under the under coating and ate everything.I already patched the foor pans ,middle rear section of the cab,next is the back lower wall of the cab.Then the entire floor of the bed.Yes this a very dawnting task but my wife gave it to me and I am now challenged.Hopfully I will get the bits and pieces all along the way
- MattsIASlickShop
this is the site i was thinking about, probably the one referenced. good description of how he did it.
http://myweb.cableone.net/jusatad/CabMount/HowTo.htm
PM me, I think I have an autocad drawing similar to it with dimensions.
Try this site. http://myweb.cableone.net/jusatad/CabMount/HowTo.htm
I need to make a pair myself for my 62 Uni.
Roy
Roy
The mounts in that link look top notch!
Sorry Charlie, you were the one I was thinking of, but I couldn't tie the fix to the member name.
66fordtrucknut wrote:I made my own mounts but unfortunately they're for a 65-66 cab, 61 - 64 are completely different. I made mine out out 11 guage steel. shame yours is so far gone. I take that your need floor pans too. Maybe you keep the back bolts in, cut out your old mounts, jack up the front if you need and just improvise some new mounts, I made templates out of thin cardboard, they only have to connect the floor to the frame. I would think they would be easier than the 65-66 mounts. BTW welcome to the club.
Charlie
I got mine from Carolina Classics. Excellent quality. I have a '62.
The guy who welded mine in (and repaired my whole floor) made some modifications that should make them much less prone to rust. Basically he welded a nut inside the cab mount so that the bolt could be inserted from the bottom. So now the nut and threads are inside the mount, protected from the elements, and the cupped hole in the floor pan (where the bolt head used to be) has a patch welded over it.
So now there's no way for water to pool in that cup and seep into the cab mount. It also made it much easier to install the cab mount bolts.
Made my 62's mounts from 2" x 3" rectangular steel tubing, much stronger than stock. Pics in my album, cost about $10 for both of them and I had the shop cut them for me. jtrammel, I have a 64 cab here for sale that doesn't need mounts if you are interested, Omaha Ne area. It only needs cab corners and a small section of toe board patched, about 8" x 10".
