someone knows the answer to this or has a spare t98 they can look inside.
before i moved i had several pto units.
i saved one and brought it.
last week i was cleaning it up and realised i may have saved a np 235 instead of a warner unit.
pretty sure the warner uses a straight tooth gear while the np435 has a angled tooth gear.
i have the angled one.
no big hurry but i dont want to dump all the oil in my trans to find out, cant find anything in the factory manual about it.
PTO question
PTO question
- F7BIGJOB
Re: PTO question
Brian, I have a pto set up on my truck, and I have an np trans, and noo I'm not going to drop it, should I look for a tag on it?
F7BIGJOB
-Steve
1965 F-250 4x4 Flareside
-Steve
Re: PTO question
SteveF7BIGJOB wrote:Brian, I have a pto set up on my truck, and I have an np trans, and noo I'm not going to drop it, should I look for a tag on it?
no.i dont expect anyone to open up their trans in their truck.
mine has no tag so no help there
someone has a trans out already.
Re: PTO question
Both have Helical (angled) gears. If using a Muncie PTO the np 435 would use a N81 input geat and the T98 would use a W80 input gear.
Re: PTO question
thanks
the pto i have is a chelsea, which input gear it has i have no idea.
Re: PTO question
I have a np435 in the garage I could open up,not sure what you're looking for.Could text a few pics.if that would help.
Re: PTO question
Brian,
My service manual has an exploded view of the NP435 and all of the gears are angled except for the first/reverse slider gear which is straight cut.
The T98 appears to be all angle cut gears.
If you need these exploded views, I can probably get them scanned and email them to you.
Kevin
Kevin
kstones63
63 F100
29 Ford Sedan Delivery
99 F250 PSD, 4x4, CC
95 F350 Flatbed Dually Diesel
63 F100
