brake pedal bushing housing broke - should I be concerned?
slixtyfive
Post by slixtyfive »
No, not the plastic bushing itself but the pot metal sleeve that is 'wedged' into the pedal mounting bracket and the plastic bushing slides into.
Should I be concerned?? I am planning to replace the plastic bushings and the broken part doesn't seem to be where the most pressure would be applied in normal use. I should point out this is a manual tran truck so technically, it serves both the brake and the clutch pedal.
All thoughts/comments appreciated.
Brian Taylor
Re: brake pedal bushing housing broke - should I be concerne
Post by Brian Taylor »
What I did and in my opinion the better repair is to replace it with a roller bear set up. Makes for a smoother pedal and will not wear out in your life time.
http://www.mustangsteve.com/clutchbearings.html
Steve sells a kit and did mine for me on my 66 F100.
1966 Ford F-100 LWB 300
slixtyfive
Thanks for the info Brian - I didn't know something like that is available.
I agree - will be sending my order in today.
douglloyd
Post by douglloyd »
slixtyfive wrote:Thanks for the info Brian - I didn't know something like that is available.
Yes, Brian, thanks for the link. I sure like that approach better too!
Funny how often all this classic 'stang and Bronco stuff works for our trucks.
Doug in east TN
