brake pedal bushing housing broke - should I be concerned?
Posted: July 6, 2014, 8:01 pm
No, not the plastic bushing itself but the pot metal sleeve that is 'wedged' into the pedal mounting bracket and the plastic bushing slides into.
Should I be concerned?? I am planning to replace the plastic bushings and the broken part doesn't seem to be where the most pressure would be applied in normal use. I should point out this is a manual tran truck so technically, it serves both the brake and the clutch pedal.
All thoughts/comments appreciated.
