Custom Cab door handle plates
Posted: August 24, 2014, 6:25 am
by 69supercj
I've got the plates but I dont think I've got any of the unique push buttons. Anybody retrofitted an extension to the standard push buttons?
Re: Custom Cab door handle plates
Posted: August 26, 2014, 5:54 am
by Leeroy
Yes, you know those small Little squares you put on the bottom of your dining chairs and tables to stop them scraping across the floor? (The hard rubber ones)
I glued (epoxy) a 1/2" square one into the plate that the button touches. Worked great! I'd buy a couple of different styles, if the pad isn't thick enough the button won't retract.
Posted: August 26, 2014, 8:24 pm
by 69supercj
Got the passenger side mounted, geez those bugers can be a real pain in the backside. I ended up making a new button shaft out of an old screwdriver that I had, worked perfect. I had one pushbutton that the shaft was separate so thats the one I used. I know one thing, if I was mounting these on a new paint job, it would be a two person operation because they are a bitch to keep together and then try to get the screws started.
Posted: August 26, 2014, 9:17 pm
welded 1\4" drive sockets on the ends of mine. been on there for many years.
Posted: August 27, 2014, 9:04 pm
by 69supercj
Got the drivers side put on today, took all of about 5 minutes. Anybody know if you can buy the pads separate? I've got a pair but they've shrunk up and wont fit.
Posted: August 28, 2014, 7:19 pm
not sure if you can buy the gasket by itself or not
ask Tom
http://www.flashbackf100s.com
Posted: August 29, 2014, 11:01 am
by 69supercj
Obsolete and Classic Parts on OK City has 'em for 23 bucks a pair. They're just going on my patina'd paint job so I dont think I need the gaskets anyway.
