Project: bagged, bodied, 66
Re: Project: bagged, bodied, 66
love the turbo ls I'm working on the same deal for my ratty 62.
got the lsx painted up and motor mounts made out of some 4 link bushings, and built a removeable trans x member, going to get that in tomorrow
had to fix the rotted out cab mounts
got the trans mount finished
i dont understand why mr henry ford decided to offset the trans tunnel 8" to the passenger side, need to rebuild the trans tunnel and for the drive shaft
had to fix the previos owners hack for the radio, start over
yea I thought the that was weird too with the whole driveline offset to the passenger side. I'm guessing youre going to run yours straight down the middle?
66 Layin Low
little progress this weekend
moved it into my other garage
picked up my bed from my storage garage
i have the floor i cut out if anyone wants it, mint shape
tranny tunnel
pushed her out for some light
went to a swap meet today, nothing good to buy,
front bed mounts
rear mounts, nuts welded into the tube, bolts through the bottom of the frame
made some white walls
tranny tunnel
front bed mounts
[imghttps://fbcdn-sphotos-h-a.akamaihd.net/hphotos-ak-xpf1/v/t34.0-12/10799309_10152792692527777_315684210_n.jpg?oh=536e3b954d675a9ccb5a5570b1c2fda7&oe=546F4C3A&__gda__=1416586830_8b37a85184f33d98ce757505badcdd45][/img]
What happened to the pics, I'm interested to see how the s10 clip looks with the fenders on. I picked up a second gen camaro clip for mine but will have to get several parts for it. I can get a compl te s10 clip for 100 so just checking all options before I dive in
Man, I haven't been on this site in forever. Saw this thread and was stoked, until none of the pictures showed up. What happened?
i have no idea what happened, sometime they work, others they dont, ill repost the majority of themdeflaytedwayz wrote:Man, I haven't been on this site in forever. Saw this thread and was stoked, until none of the pictures showed up. What happened?
Since most of the pictures are gone for some reason ill start over here
This is where im at now, as you can see, ditched the ls twin turbo for the cummins i had in my bagged dually, inside the cab is pretty much done minus wiring, gauges etc, next ill pull the cab, finish up the firewall, seam seal under the floor and paint the rest of it, then fuel lines and brake lines on the frame and put the cab back on for the last time
things to do before driven
rear brakes for the 9"
wire harness
fuel lines
brake lines
sending unit
put the motor in
find a rad that fits
mount body panels
and buy a trans
wire harness
fuel lines
brake lines
sending unit
put the motor in
mount body panels
and buy a trans
