To Reomve or not to Remove? the door skin...that is my quest
624WD
Post by 624WD »
I am thinking about removing and then reinstalling the door skins to install sound deadener in my doors (like the Astronaut did on his build). Is there a tool that will help with this? Or, is it best to drill out the spot welds and pry the skins from the door?
Or, better yet, can I spray a product such as Lizard Skin sound deadener inside the door through the removable door panel (after I remove the window assemblies?) - and save myself time from removing the skins. ???
This is not a concourse resto but a good solid truck resto to be used as a daily driver.
Thoughts? advice? beer?
Thank you in advance
Tom
624WD
Re: To Reomve or not to Remove? the door skin...that is my q
Post by 624WD »
How do I fix a typo in the Subject line?
624WD wrote:How do I fix a typo in the Subject line?
use the edit function
i would not remove the door skins , theres lots of room to spray with the panel out and the door off to be able to flip around as needed
mercuryv8
Post by mercuryv8 »
X2. That is a lot of effort to get sound deadening in.
Nic
624WD
Post by 624WD »
I agree... Spraying the insulation and sound deadener will work just fine. Case closed. Thanks. Tom
64 f100
Post by 64 f100 »
Remove door skins? Not unless your a masochist, and haven't beaten yourself lately.
1961 F350
1964 Galaxie convertable
1965 Ranger, and shortbed
1966 long bed, and shortbed
A few parts trucks also
1991 Capri
2011 F250
2004 Lexus
mercuryv8
Post by mercuryv8 »
64 f100 wrote:, and haven't beaten yourself lately.
Bah ha ha...
Keep it clean.
624WD
Post by 624WD »
It might hurt so good. Maybe it would be best to have a 9" rear end drop on my toes before I do that. :)
