when i was younger i made a frame out of 1/4x1/2 angle iron around the inside of the bed, then i got 3/4 in plywood and cut it to fit inside the bed in 2 sections, then i drilled holes in the angle iron tak welded some 1/4 in bolts in drilled matching holes in the playwood, wrapped the plywood in some vynal like they use on morocycle seats with a thin layer of padding on it, used wing nuts to hold it down, we could lay on top of it at the Drive in Movies or remove it easily if needed, i had access to stainless material , it never rusted and looked good to,ill see if i can dig some pics
________
buy glass bong
Bedcover ideas???
Doc,
You looked at what I had to do to cover the bed on mine, you might do something along the lines of the Silver Shield. Would be a lot lower, about to the bottom of the rear window.
While messing in the garage, I found one of those airgate things that I took of of another old pickup I had. If you want it, just let me know, and you could pick it up next trip through or some other arrangement. I don't get down there anymore.
Fred
Fred
Doc, go to your local topper/truck accesories store. There are several companies out there that make an aluminum framed soft tonneu, can be gotten hinged for a small additional price. These can be made to order for about the same $ as a standard size for a late model truck. Comes in aversoin tha leaves the frame on the bed and rolls up, range of colors too.
