vin plate decoder
vin plate decoder
can someone link me to a site i can decode my vin plate? or decode it for me?
If it wears make up or has wheels and a motor i want to play with it!
Re: vin plate decoder
http://home.earthlink.net/~threynolds2/ ... s6166.html
for the F100s.
for the F100s.
thank you
- banjopicker66
I'll decode it for you, if you wish.
Post the entire Warranty Plate, not just the VIN. I can give you the trim codes too.
Thanks x 2.Toyz wrote:http://home.earthlink.net/~threynolds2/ ... s6166.html
for the F100s.
What about trim codes for Mercury's ?banjopicker66 wrote:I'll decode it for you, if you wish.
1964 Mercury short box 460 innies
- banjopicker66
I have the Ford parts books on CD for '58 or so to '68 or so. It doesn't have Mercury codes.wwhite wrote:What about trim codes for Mercury's ?
Maybe I Have A Fleet Truck?
Deleted, moved to new topic.
why is the valve cover odd
if it is because there are no holes on top for pvc the engine had a road draft tube originally
N is the correct np435 code for 1965
in 1966 it was changed to A and that was used 1966-1986
