Did I Buy A Fleet Slick?
Posted: February 27, 2015, 2:45 pm
by chris401
http://home.earthlink.net/~threynolds2/ ... s6166.html
My truck matches the above link except the N transmission code. I have a run of the mill NP435, unless mine has a gear ratio difference. Nothing different from any car/pickup 352, but it did have this odd valve cover color and carburetor govenor pictured.
VIN: F250DK******
?:129 Color: M Model: F250 Body: 581 Transmission: N Axle: 24
GVW: 7500 Net Hp: 172 RPM: 4000 DSO: 632754
Re: Did I Buy A Fleet Slick?
Posted: February 27, 2015, 7:31 pm
copied and pasted from the other thread where you deleted your post and started a new one
why is the valve cover odd
if it is because there are no holes on top for pvc the engine had a road draft tube originally
N is the correct np435 code for 1965
in 1966 it was changed to A and that was used 1966-1986
the governor is usually found on commercial fleet trucks and school buses, i have mostly seen them on f350s and bigger but its not out of the ordinary to see them on lower models too.
Posted: February 27, 2015, 8:07 pm
by chris401
If you have literature will you do others a favor and check that link for other mistakes? I ignored your comment below because I said nothing about pcv. I was giving you a chance to reread it.
Edit: You cleared up info on the carb spacer, I haven't seen anything close to that on a small slick.
Posted: February 27, 2015, 9:28 pm
by Toyz
1965 Code N represents the NP 435 in the '65 f100/350. For the heavier trucks it was code "A for 1965 models. As Brian stated, it was code "A" for all applications starting with the '66 models.
The only errors I have personally noted in the Didgey listings involve trim codes. It is far from complete, but provides an easy to find resource particularly for the lighter trucks.
Posted: February 27, 2015, 10:43 pm
by chris401
Did you read my code I put in post or am I missing something in earthlink?
Posted: February 28, 2015, 8:47 am
by Toyz
Did you read my "far from complete" statement?
Posted: February 28, 2015, 11:53 am
by F7BIGJOB
Chris, my '65 F250 has the 'N' code too.
