looking for wide whitewall radials for lowered 61stepside
OK this is what I have.I have a 61 f100 2wd short box stepside.It is lowered 4 inches in the rear with mono leafs.and 3 inches up front with a 3 in drop axle from nostalgia sid.l'm looking at ordering WV genies 15x8 witth 4 inch in bs. (please chime in if I'm wrong or if you have better idea). I'm looking for some wide whitewall tires(as in tires with wide whites) . I have no idea what size would look good or what particular tire brand. I would like some wider tires in the rear as this truck is a 620 hp 521 scj big block and lentech strip terminator aod. Any help from someone with the similar truck would be great. I want some tires that will really look good as far as size. This is my first slick so help please and thanks.oh steel belted radials please no bias ply
Re: looking for wide whitewall radials for lowered 61stepsid
I am running 225/70/15 on the front and 255/70/15 rear. My rear wheels are WV steelies 15x8 and the fronts are stock but reversed 15x6. Some guys run 275/60's or 295/60's on the rear which does look meatier. I have mono's on the front with a 4 1/2" drop and shackles and reversed hangers in the back with 5" drop. Just my
Post up pics when you can...we like pics...
Speaking of Wide Whites. I saw a video on Youtube of a Rat Rodder who ground his own white walls using an electric angle grinder and raised white letter tires. Looked pretty easy and really great when he was done. I thought about trying it but I don't have the guts to take a grinder to an inflated tire!
https://www.youtube.com/watch?v=YN2y0XIbW8Y
Here is the link ^
This may work for you Chuck. Anyone ever tried this?
Justin
Here is the link ^
Justin
I saw those videos on youtube a while back when searching for crown vic swaps into Slicks. Good info and turned out nice.
Dave's 61 Uni short bed build is the name of the thread...it's in the Projects and Builds section on here.
Try these guys. They have speed rated WWW radials. http://www.dbtires.com/
