trailer hitch?
rooster91
trailer hitch?
Post by rooster91 »
anyone know of a cheap trailer hitch? $100 ish or under. doesnt have to be that heavy duty
If it wears make up or has wheels and a motor i want to play with it!
banjopicker66
Re: trailer hitch?
Post by banjopicker66 »
The local U-Haul installed a new Class III hitch for about $150.
Did not include wiring up lights for trailers, though. I did the wiring myself.
The hitch was made for our Slicks, with one exception on my '66: One bolt hole in the hitch was obscured by a frame rivet, so they just drilled another one through the hitch and the frame, and used grade 8 bolts.
64 f100
Re: trailer hitch?
Post by 64 f100 »
Try a salvage yard. Frame width is the same up to 72 on the trucks, so it shouldn't be to hard to adapt one if slightly different.
1961 F350
1964 Galaxie convertable
1965 Ranger, and shortbed
1966 long bed, and shortbed
A few parts trucks also
1991 Capri
2011 F250
2004 Lexus
Re: trailer hitch?
LMC has a bolt on receiver hitch to fit 63 - 72 model trucks.
Item number 48-1760. Black powder coated and rated to 6,000 lbs
ClassIII with a 600 lb. tongue weight. Can't get it much easier than that.
TR.
