GM one wire alternator... What do I eliminate?
Posted: May 12, 2015, 10:03 pm
Sorry if this is an old topic. My dad said this was popular back in the day, and although I've been googling for 3 days I have yet to find a tech article that's idiot-proof enough for me.
I have a freshly built GM one wire alternator from a 52 styleline with the 216. It was rebuilt and run for maybe 100 miles before being garaged for the past 15 years. Swapped the motor so the alternator is available.
I have a 64 F100 with a 223 with the original generator. Mounting should be easy... Drill some new holes in the bracket and move it up to align the belts. All-thread through the bottom and make the top bracket work.
Wiring is where I'm fuzzy. And please forgive my lack of correct terminology. My dad says run the single wire straight to the battery. My question is about the voltage regulator since the generator is wired through the regulator. So I'll be eliminating the two little black wires and big yellow one...
Then I'll take out this box since there's a charging regulator built into the GM single wire...
I'm guessing this is a fusible link? Also history...
And now finally, the voltage regulator. At least I think that's what it is.
Looks like right side is positive and left is ground. Not sure what the two little guys on the front are for.
So will I run my charging wire from the alternator to the positive side or just straight to the battery cable? Does it make a difference? Seems like there's power already going to this box. That yellow wire is the same one hooked to the current generator right?
Thanks for clarification. I'm still learning how all these gadgets work.
