Stock speedo to zf5
Posted: July 1, 2015, 12:25 am
by 64oilburner
Has anyone come up with a way to connect the stock speedo to a zf5, 7.3 diesel and 4x4 if it matters.
Re: Stock speedo to zf5
Posted: July 1, 2015, 6:31 am
by bruceandersson
If the zf5 (I assume this is the trans) has an electronic sender, you may be facing a challenge. Could you use the guts of an electronic speedo with the stock face and needle? I think the electronic ones are adjustable so you might be able to get it to read accurately.
Posted: July 1, 2015, 7:50 am
by rbeck204
I used a "Cable X" box (made by Abbott) to convert the electronic output to drive my stock speedometer in my 61. Fully programmable calibration so once tires are installed, the speedo can be set perfectly. I believe Dakota Digital also sells a similar unit.
Posted: July 1, 2015, 10:59 am
by 64oilburner
That cable x box looks like it would be the vest way to go about it. Its been so long since i swaped the tranny in i cant remember if it had a cable or sensor. Ill have to take a look.
