I'm finally getting started on the build. Took awhile to gather some of the parts and motivation but that is finally coming together. Here's what I started with.
After I cleaned it up a bit.
Sand blasted the front of the frame and moved it into the shop.
It's going to need some floors.
Some work in the bed.
But it could be worse.
62 Unibody shortbox, 5.0/AOD, Dakota front end, rear axle over
Made some progress today, I was able to get the crossmember tacked in. As soon as I am able to pick up my Dakota parts I will be able to finish the install.
Still a long way to go but it's starting to get to go in the right direction.
I still haven't decided how I should lower the rear.
When I first lowered mine in the rear, I just took out leafs until it sat where I wanted it. But that was a little soft. Then I swapped out the springs for a newer set and flipped the axle to the top of the spring. With the CV front end in it, the rocker of the truck sits parallel with the ground.
plus many other's!
I've been thinking of flipping the axle. How did you handle the shock issue? I wonder if the Fatman Fabrications or Airbagit kits would be a good idea.
I just removed the overloads, extended the rear spring shackles like bigredtod did on the 62 land spreed uni viewtopic.php?f=32&t=19250&start=60
I used a different ifs but it got low enough for my needs
Sorry, this is the best pic I have of it right now. The frame actually leans a little forward to mimic the angle of the original shock placement. I notched the frame aswell. Most guys lay the shocks almost flat, and at that point they really don't do a whole lot.
This will all be gone shortly, I hope! I have am independent out of a Mark VIII I want to put in.
plus many other's!
I take it you aren't happy with the current setup? A buddy of mine is trying to convince me to put in a four link and coil overs. He says I will be much happier with the ride.
I don't mind the ride, it a little choppy, but it handles like a go-cart. Its actually quite fun to drive. The independent will give me a usable box back, and the rear won't bottom anymore. Plus, I've got the mark VIII just sitting there, may as well use the parts.
plus many other's!
That four link looks good as well, my only question is how far above the original elevation of the box floor will the kickup protrude?
I may be alone on this, but I don't care for the look of a floor with a raised portion between the tubs to clear the kicked up rails (or the top of the diff) ..... I would rather have the whole floor raised than only a portion.To me, the floor looks better flat, and does not hinder loading or carrying cargo, other than the loss of some depth:)
