65 thru 72 Crew Cab Frame Questions
jamesdfo
Post by jamesdfo »
This is directed towards anyone owning a '65 thru 72 Ford (or '65 thru 68 Merc) factory built (ie: not Coachbuilt) Crewcab.
On my 1966 F250 2WD Crew with 147" WB (and BTW, it's a SWB Styleside box), the framerails have been "Fishplated" on the outside. The plate begins right behind the Radius Arm Bracket, and follows the contour of the rail all the way back to just in front of the forward Spring Hanger Bracket for the rear diff. The Fishplate is made from ONE PIECE (no splices), and has a bunch of holes drilled in it, and I'm sure there are also "reliefs" drilled on the backside to allow the plate to sit flush to the rail where ever there are rivet heads protruding where the crossmembers are riveted in.
I did find a thread on FTE where the owner showed frame pics of his 1972 F250 2WD, and the plates on his frame are very similar to what I see on my 1966....
So, my question(s) to owners of '65 thru '72 factory built (ie: not Coachbuilt Crews are:
1) Does your truck have the fishplates? Y/N
2) If yes, what is the GVW?
3) Any chance you will share the info on your data plate with me (not expecting it on forum, by email)
I have been in touch with a fellow @ the Ford Archives, and although we are fairly certain these were factory installed, so far, we have no documentation to confirm this. If we can get some input from other Crew owners (particularly 67 thru 72 Trucks), we may have a way to confirm this.
Thanks in Advance
James
65 crewcab
Re: 65 thru 72 Crew Cab Frame Questions
Post by 65 crewcab »
mine is a 66 ford with a 147" wheel base 2wd it to has this plate the GVW is 7500
1966 crewcab
jamesdfo
Post by jamesdfo »
Thanks for responding, PM sent:)
65 crewcab wrote:mine is a 66 ford with a 147" wheel base 2wd it to has this plate the GVW is 7500
