1962 unibody trailer hitch
Posted: September 11, 2016, 11:48 am
by bbrix
Hi folks. I have been searching, to no avail, for a trailer hitch for my 62 unibody. Maybe I'm searching improperly. Could use some advise or ideas here. Thanks, B
Re: 1962 unibody trailer hitch
Posted: September 11, 2016, 12:23 pm
by jamesdfo
The chassis under your Uni is the same as any of the conventional cab straight axle models (of the same series, ie F100 uni vs F100 conv cab, F250 Uni vs F250 conv cab) up to 1964, the only unknown is weather or not commercially available hitches will clear the rear "Valance" panel.
Posted: September 11, 2016, 2:02 pm
by bbrix
jamesdfo wrote:The chassis under your Uni is the same as any of the conventional cab straight axle models (of the same series, ie F100 uni vs F100 conv cab, F250 Uni vs F250 conv cab) up to 1964, the only unknown is weather or not commercially available hitches will clear the rear "Valance" panel.
. Ok, the would explain that when I do a search I am always told this hitch will not fit my truck. I'm thinking I should take more careful measurements of my own, IE bottom of frame to bottom of valance and search using those perimeters. I appreciate the input. We would like to pull our restored 1958 Oasis camper with this pick-up.
Posted: September 12, 2016, 6:54 am
by bruceandersson
A good trailer/hitch store will build one for you. May cost a little more. I think the rear frame is the same width up thru '72. One of these might be able to be made fit. I bought one for my '66 not too many years ago that was an easy bolt-on and left he spare in place.
Posted: September 12, 2016, 6:34 pm
by FarmMotorSports
https://www.etrailer.com/hitch-1963_For ... tep+Bumper
They don't show a class 4 or 5 hitch for our trucks. But they do show several hitches.
Just enter you year bla bla bla an ta da....
More $$$ than I'm willing to spend.
I pulled a class 5, from an other brand toner in the wrecking yard for $10.
I'll narrow it down to fit my frame.
