Fluctuation in Idle speed
ThinLizzy13
Post by ThinLizzy13 »
My '63 uni with a 223 and Autolite 1101 with a manual choke has an odd fluctuation in idle speeds. The best way I can describe it is it is acting like an automatic choke.
The truck will idle fine at 500-550 rpm. If I hit the gas quick it idles up like a choke was set to around 1000-1200 rpm. Sometimes I can get it to idle back down by pumping the gas, but most of the time it either stays idling high or will idle back down randomly.
I sprayed for vacuum leaks around the carb and did not find any. Timing is good; ignition is set to spec; truck otherwise runs perfect.
Am I missing something obvious here? :hm:
Re: Fluctuation in Idle speed
By the way you are describing...
If I'm understanding correctly...
It almost seems like you have some linkage hanging up...
I know the pedal hinge on mine was tight...
Had to take it out to lube it up...
Was it always like this... Or just get a little worse over time ?
If so... I'd say some linkage lubrication would help
ThinLizzy13
Thanks slick4x4, I think you're right. I found if I tap the pedal just right I can get it to idle down. I'll lube up the linkage tomorrow and see if that frees it up.
Leeroy
Post by Leeroy »
Check the return spring on the carb also. Had this exact problem recently.
