Engine angle
Posted: April 1, 2017, 4:27 pm
by Blackwaterforge
I am installing a different engine.
What is the angle of the output shaft of the transmission?
My pinion angle is 6 degrees with no engine.
Thank you!
Re: Engine angle
Posted: April 1, 2017, 9:10 pm
by Hunter's 64
ive always just leveled engine in truck by carb. mounting plate, tail shaft angle is what it is, drive shaft u joints should take care of diffrences ?
Danny
Re: Engine angle
Posted: April 2, 2017, 12:02 am
by FORDification
Try looking over the Body Builders Layout Books...they might help. While they don't specifically give a measurement in degrees, they do specify how much lower the transmission output shaft centerline needs to be below the top of the frame.
http://www.fordification.info/tech/bodybuilder.htm
Re: Engine angle
Posted: April 2, 2017, 10:08 pm
by third66go
Stock angle is 4.66 degrees...its on those frame dimension sheets, but hard to pick out.
Re: Engine angle
Posted: April 3, 2017, 5:02 am
by Blackwaterforge
third66go wrote:Stock angle is 4.66 degrees...its on those frame dimension sheets, but hard to pick out.
Thank you
That is what I needed to know
