rolled it over
Posted: May 3, 2017, 6:52 pm
the odometer, not the truck.
looked cool for a few seconds all them 0's in line.
wonder how many of you have done this in your truck
Re: rolled it over
Posted: May 3, 2017, 8:37 pm
by aj64f100390-292
Mines about to, currently at 98,675 but its rolled over with dad several times since the mid 90s...but the speedometer is off...but we think the 64 could have 500k miles...but there's just no telling for sure...
Re: rolled it over
Posted: May 4, 2017, 6:08 am
by Day 2
Mine saw all zeros in 1998 when I reset it while doing a body off redo, its got 39986.3 right now, not bad for 19 years, considering my 2005 Ram has 38000 on it now.....
Re: rolled it over
Posted: May 4, 2017, 6:14 am
by bruceandersson
I don't think mine has ever rolled over, somewhere around 89,000. But the title is listed at 840,000 or so because the young person at the title bureau had never seen an odometer with a decimal place indicated by reverse colors. I did not notice until after I had the title and did not feel like going back through the lines to get it corrected.
Re: rolled it over
Posted: May 4, 2017, 11:54 pm
by Michelle
What's really strange is when my truck rolled over to 43,000 miles, The truck had 42,000 when I bought the truck and the speedo worked perfectly. When it turned over to 43,000 it stuck and the speedometer needle started jumping from like 10 MPH to 70MPH the thing just went crazy and the odometer was stuck on exactly 43,000. About ten miles later the odometer started working again and the needle started working normally again. The cable is greased well, no kinks in it. It was totally inexplicable, it has been working perfectly ever since.
Re: rolled it over
Posted: May 9, 2017, 6:26 pm
by aj64f100390-292
Michelle wrote:What's really strange is when my truck rolled over to 43,000 miles, The truck had 42,000 when I bought the truck and the speedo worked perfectly. When it turned over to 43,000 it stuck and the speedometer needle started jumping from like 10 MPH to 70MPH the thing just went crazy and the odometer was stuck on exactly 43,000. About ten miles later the odometer started working again and the needle started working normally again. The cable is greased well, no kinks in it. It was totally inexplicable, it has been working perfectly ever since.
Thats wild Michelle...hope mine doesn't do that...to be honest I forgot to grease my speedo cable when I put mine back together....need an adapter so my speedometer is accurate...dont want to do to much until I decide what transmission im going to swap in and weather or not to keep my 16" wheels..
