Heater core?
Heater core?
Does anyone make a replacement for a '64?
- bobenhotep
Re: Heater core?
If you find someone that does, please let us know. It is one of the parts that as far as we know, they don't make repops.
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
"The Iron Rhino"
-duraspark II/ HEI
Re: Heater core?
What about something that will inter-change?bobenhotep wrote:If you find someone that does, please let us know. It is one of the parts that as far as we know, they don't make repops.
Re: Heater core?
an odd core due to the tube shapes
heres the 61-64 and 65-66 side by side
some others that do not match due to size and tube styles
best thing to do is find one from a parts truck, clean it up and repair if necessary and save it as i have done.
Re: Heater core?
Are the tubes soldered on?ICEMAN6166 wrote:an odd core due to the tube shapes
- bobenhotep
Re: Heater core?
There was a guy who soldered one together out of an econoline core. I know when mine goes out I will figure something out.
"The Iron Rhino"
-duraspark II/ HEI
"The Iron Rhino"
-duraspark II/ HEI
- bobenhotep
Re: Heater core?
"The Iron Rhino"
-duraspark II/ HEI
"The Iron Rhino"
-duraspark II/ HEI
Re: Heater core?
I used this heater core, Four Seasons 94576 Heater Core and used 1/2" copper tubing and fittings to copy lines from old one it worked perfect. I don't know how to post pictures, or I would post pictures of it.
It was for a 61 unibody, but I think they are the same as 64. Just make sure you get the copper core.
Semper Fidelis
1961 f100 Unibody BBW
2002 Excursion 7.3 (the bus)
1982 Bronco
2017 F150
2017 Mustang GT/CS
1982 Bronco
2017 F150
2017 Mustang GT/CS
Re: Heater core?
https://www.summitracing.com/parts/fss-94576
http://www.rockauto.com/en/moreinfo.php?pk=946774&jsn=9 they have 4 @ 20.79 ea but they are alum. core not copper
Danny
Danny
Re: Heater core?
Aluminum is all I am finding with that part number also. But you can use uniweld 4300 to solder the two together.Hunter's 64 wrote:https://www.summitracing.com/parts/fss-94576
Danny
Re: Heater core?
I can not tell you part numbers but I bought one on e-bay, made of copper, that matched core size, cut off the old tubes and soldered them on the new core with 1/2" copper fittings
Re: Heater core?
I would think you could take it to an A/C shop and they probably have a fitting to go from alum to copper some how
Danny
Danny
