New switch, cylinder, bezel and other associated items. The switch seems to be in a bind such that it will not rotate back from "start". Everything is lined up and it will turn freely when not installed.
Any thoughts on what I need to do?
Ignition Switch Issue
1964 F100 Flareside, all original w/ Y Block 292
Re: Ignition Switch Issue
Have you tried any lubricant,might need a few clicks to get everything in order....just a thought.
Reset the lock by pushing a pin in the hole and rotating counter clock wise,to same position you removed the old lock just past the acc position.
Make sure you match both lugs, and switch nub position on lock, to switch. it will then slide all the way in and turn freely to off position.
Never wet lube, switch or lock, graphite works best and will never gum up.
John
John
I have run into the same issue, seems if I push on the back of the switch so the lock cylinder is slightly forward in the bezel it turns free. Going to try a different ignition switch, didn't have this issue with the old switch.
64 Ranchero (has new owner)
65 F100 shortbed
66 Mustang (A code 289)
67 Bronco
65 F100 shortbed
67 Bronco
So, if you completely assemble the switch,cylinder, with backing cup,spring and bezel, it moves freely until you try and install it on the dash?
I know it is a pain to reassemble in place but if all the nibs on the cup are put in place and the locking cylinder is properly installed it should turn the same whether in place or not.
Anyone else have this issue??
- 6166 Junkyard Dog
first issue is who's switch is it aftermarket or ORIGINAL FORD SWITCH ????? and by Ford I mean not a replacement OEM
Kathy
Now Cooper will try his best
I've had this problem with an aftermarket replacement switch in the past.
Switch and all other parts came from LMC. Works perfectly when fully assembled outside of dash. Install in dash and its like it binds up.
- 6166 Junkyard Dog
Well that explains it, Larry ,Moe and Curly strikes again
Kathy
castruck_1964
What Dog means is the LMC are not genuine Ford and Aftermarket ones are all Crap had one come apart on me. I was not genuine ford.
Slicks rule
dd/ 19 F150,97 Tbird
62 swb bbw uni next project
460 C6
Ken
460 C6
Ken
