I have a 65 F-100 and am trying to figure out where the washers hook up to electrically so they can be actavated. I noticed that if I pull on the wiper switch it seems to pull out and retract when let go of, I don't know where to go from here. Any help will be appreciated.
Thanks,
wind shield washers
wind shield washers
I have a 1965 short bed step side F-100. It has a 302 V8 in it.
I believe that the push button switch above the ignition switch is for the washers. 66KIXX has that switch and the original hood had the holes for the nozzles. But that hood is gone so I can't give dimensions.
Tracy
Tracy
1956 F-100 Panel w/429 (3.50 9")
1966 F-100 SWB w/351C (3.25 9" - 3.70 posi for Saturday nights)
Music City F-100's,
1965 GT-350 S/C (2.78 1st & 3.70 TracLok 9")
Music City Mustang Club
1969 Schwinn StingRay
Don't focus on the destination....make the JOURNEY the adventure
Music City F-100's,
washers
Thanks Tracy for the quick get back. I have the nozzles in place and all the plumbing finished. I also hot wired the pump to be sure it was working and all is a go. Now you mentioned a push button above the ignition switch, that is where the lighter is, maybe that's not where it's suppose to be but it's there. I was thinking of putting a door bell type push button switch somewhere maybe even under the floor mate, but was just wondering if it somehow hooked up to the wiper switch.didgeytrucker wrote:I believe that the push button switch above the ignition switch is for the washers. 66KIXX has that switch and the original hood had the holes for the nozzles. But that hood is gone so I can't give dimensions.
Tracy
This truck started it life out in the Army at the Rock Island arsional, and I've found a few things different about that were Government call outs, so I wasn't sure if I didn't have something different here. If you have any other thought's I'll be more then happy to have them.
the knobs which are spring loaded (pull out) have a tab on the backside where power to the washer pump is connected.in 68 or 69 they switched to the push-in type. you can use either of these .
the pushbutton in the vent pull hole is easy to hook up , saves changing the whole wiper switch.
no rhyme or reaon that i have deduced as to which were installed on which trucks, i have not seen a pattern.
the foot pump is also an option, used up to 64 on the f100/250 and all years on all the bigger trucks.
