Throttle spring
Posted: August 17, 2017, 9:07 am
Some of you may have experienced the same problem as I have with throttle not returning to idle. This of course could be a result of the throttle cable, which is not very good in my opinion, but trying to et it to work right by changing spring tension, and it is not working out all that well. First let me state the throttle does not want to come off the idle position, and takes to much pressure which makes the old gal harder to drive. If I stretch the spring then it does not want to go back to idle. Cable seem to be in fairly goo condition although used and not new. I also have another problem and that is the carb does not want to idle down all the way. I'm wondering if the wrong carb has ben installed sometime in the past. I have to put to much pressure on the foot pedal to get it off idle. Annoying at the least as the engine will be turning to many rpm for easy driving. I am also am working on my grandsons truck which I have installed a 351w in. Using the later mounts puts the engine and carb further back in the engine bay, which leaves the a tight circle for the new carb cable. I don't like the setup and think it will cause problems in the future. I am using a modified 352 bracket and original replacement style cable. Frankly, I've never liked the original cable setup but personally know of nothing that is an easy replacement. I have 351w cable brackets for the intake, but this uses a different cable and again it would be twisted around in a pretzel fashion. Any solutions out there that don't bankrupt the bank. As is, I have 35 plus shipping in the NORS cable I used.
