New steel bed floor sections coming!
- needmoretime
Carolina Classics is asking for feedback on the possible release of steel bed floor sections. Rick has these calculated to ship reasonably in sections. A whole floor would be cost prohibited due to shipping size. Either way he needs to know your feedback before investing in the expese of dies and production. Your support allows repop parts to become reality.
Thanks for helping with this,
WK
[albumimg]2930[/albumimg]
WK
- jkimbrel65
- needmoretime
- 65 F100 CC
- dotcentral
Man, if they do them in the sections pictured, that makes for some mighty long welds. A nice, new, straight, rust free bed floor sounds awesome, though!
- needmoretime
Alright, would you spend hundreds of dollars shipping a whole floor or get a whole floor in 3 sections and piece it together? My thought is most everyone only needs pieces and sections and would not replace an entire floor. It would be possible to replace the whole floor and if that is the case a long weld on a truck thats needs a whole floor is probably not as big a deal as the project itself! Most beds need the front and rear unless a big ol 352 was rolling around in the back.
Ok, I hear ya.
Sooo...is it better to have them made in sections running front to rear, or side to side? For example, usually the rust at the front of the bed goes all the way across, so having one piece would be nice...but trying to weld across all the peaks & valleys could be a pain.
In the case that a guy would want a whole floor, I suppose the three sections could be laid out on the floor, welded up, then lifted into the bed as one piece & welded in from there.
Maybe the repop pieces could be made with stepped flanges pre-made into the pieces, so they sorta fit together like a puzzle as you tack 'em together?
I dunno, I'm just spitballing here.
Regardless, I'm happy to see more good repop stuff coming our way.
I think this product offered in sections will benifit many projects but I DEFINATELY see where you are coming from Slick Fan. I am going to replace my floor in one section. My bed floor has rust issues and the seam (just welded in a few spots) where I shortened my box. The body shop I deal with at work hooked me up with a guy that has a damaged '03 Superduty box. The floor is good, the measurement between the wheel tubs is the same as my '66 slick box, and the "ribbs" are very close if not exactly the same as the slick. I will definatly be a challange removing the "material" but I think in the long run it will be worth it. I'm stoked, I pick up the Super Duty box tommorow night.
Sounds great! I'm betting the ribs are a bit different from a purist standpoint, but who cares? A nice, straight, rust free floor will be the prize!
Show us some pics of the ordeal when you can.
JC Whitney already sells 1/2 sections. That market is taken care of. I would love a full section bed floor. I've actually been looking for years for such a source. I ended up buying a used bed from a junk yard with a good floor, but finding that took years too.
I have no problem with fabbing two pieces together, but I wanted a clean full bed floor with straight as an arrow lines.
My Slick is rustier than your Slick!
- DV65CustomCab
If they were to purchase a pressbrake rib die at least 8' long, they could run it in a 12' press and offer several configurations, including a full floor. Thing is though, it probably wouldn't be exact (I think some of the ribs are continuous and some aren't), as the ribs would all have to be the same. The panel size would only be limited by the blank you started with. Some floors might be a custom order if you wanted larger panels. Just a thought.
