1964 sill plate passenger side
I need a sill plate for a 64 passenger side
Re: 1964 sill plate passenger side
What exactly do you need? There is the rocker panel, step plate and riser. Which do you need? I have a 1 new rocker panel and new risers for both sides.
What the OP is looking for is the Aluminum Trim piece that was used on a very small number of trucks. It was a finish piece, which also held down the Floor Mat...........
James
James
Another option would be the solid aluminum ones MFG's by Slick 60s member Kstone
https://www.copperstatecomponents.com/f ... _trim.html
James
James
