Time for ... uh ... timing
- bigtrip460
- 66fordtrucknut
- Hoofbeat Racer
Doc, I understand you are running a vacuum advance on your distributor. I know from my experience, I got to play alot with timing back in the day in school. Most important rule of thumb in my mind is to run your vacuum advance on your venturi vacuum port on the carb. By using manifold vacuum, you lose your vacuum advance as the engine revs or loads. I would set my base timing with the engine warm, idle at a comfortable speed, and remove the vacuum hose from the carb. Once you found your 10 to 14 deg, wherever you feel comfortable, install the hose back on (ported vacuum) and your timing increase should minimally change. As you rev (or load) up, vacuum advance will increase due to greater demand from the engine for air, hence venturi vacuum increases. Your mechanical will start to kick in as your distributor velocity increases. I found on my old (I know way to big for a slick, 460 LOL), that I was able to achieve about 47 degrees total timing without any issues. That was from a modified stock distributor. I haven't set up my new MSD yet, but it shouldn't be much different.
Here is my first kick at some tech support in a while, hope it helps
Mark
