Items removed from my 390 when I went to a tri power setup
1) water neck with bolts bead blasted good cond- $10
2) carb spacer with PCV hose perfect shape - $10
3) heater hose nipple bead blasted- $10
I also have the 2bbl intake if anyone needs it. - $25
Shipping all items on your dime
FE stuff
FE stuff
- Power brakes
- DJM drop beams
- Power brakes
- DJM drop beams
Re: FE stuff
Still have the water neck and heater hose nipple...
- Power brakes
- DJM drop beams
- Power brakes
- DJM drop beams
Re: FE stuff
bump
- Power brakes
- DJM drop beams
- Power brakes
- DJM drop beams
Re: FE stuff
I’m in need of a double alternator pulley 3”dia.
hoping you might have one,my old one will not come off
Re: FE stuff
nope
- Power brakes
- DJM drop beams
- Power brakes
- DJM drop beams
