No rear brakes
LA 66
No rear brakes
Post by LA 66 »
About 8 years ago I converted my 66 F100 short to disc brakes using 70's parts. I was never very happy with the results, but it stopped ok and I didn't have time to fool with it anymore. Fast forward to last month, my other truck was down and I had to pull a heavy trailer to the dump. I could not stop without the trailer brakes. The front wheels would lock up and slide. Running the truck in gear on Jack stands confirmed the rear brakes were not working. Standing on the pedal did nothing to slow the rear wheels.
I replaced the wheel cylinders (stuck) and master cylinder (i couldn't get the old one to bench bleed). Still have the same problem, but with a much firmer pedal. I've bled the brakes multiple times with no improvement. What next?
Background info:
  • 67 F100 vacuum booster
    74 F100 master cylinder
    78 F150 beams, spindles
    72 F100 rear drum brakes
    78 F150 combination valve
William in LA (Lower Alabama)
1966 F100 SB - 352/3spd
1965 F100 SB CC - sold
1966 F100 SB CC - sold
1966 F250 Work body - sold
1967 F100 SB CC - 360/C6 - sold
1971 F100 Long Flareside - 390/4spd - sold
1972 F100 XLT Ranger - 360/C6 - Gramp's old truck
Plus '53 CJ3B, '54 CJ3B, '67 CJ5, '70 Jeepster, '71 Jeepster
Mr. Jones
Re: No rear brakes
Post by Mr. Jones »
From what you described it sounds like the rears just need adjusted out,since you were able to bleed the system there’s pressure back there so your lines must be good......I think these slicks never came with self-adjusters....
FarmMotorSports
Re: No rear brakes
Post by FarmMotorSports »
Does it have the disk drum safety (proportioning) valve on the frame?
If so, is it stuck shut for the rear brakes? have you checked the rubber line to the rear axel for internal damage that is plugging it...
61 F250 Unibody
5.9 Ford Diesel / Allison
Disk brake straight axle
LA 66
Re: No rear brakes
Post by LA 66 »
Mr. Jones wrote:From what you described it sounds like the rears just need adjusted out,since you were able to bleed the system there’s pressure back there so your lines must be good......I think these slicks never came with self-adjusters....
I bled the brakes with the drums adjusted tight, then backed them off until the wheels could turn with very slight drag. It does have self-adjusters. The rear brakes are the wider 68-75 drums (complete swap - backing plates, axles, etc.).
FarmMotorSports wrote:Does it have the disk drum safety (proportioning) valve on the frame?
Prop valve - yes. From a 78 F150.
The lines are all copper-nickle that i did when I put the discs on. Hoses were all new then, too.. I get plenty of fluid at each wheel and there aren't any leaks.
unibody madness
Re: No rear brakes
Post by unibody madness »
Have you tripped your pressure differential switch on your brass metering/regulating valve? if you do not have the light switch hooked up, check it with a multi-meter or simple test light hooked up between power and ground .
LA 66
Re: No rear brakes
Post by LA 66 »
unibody madness wrote:Have you tripped your pressure differential switch on your brass metering/regulating valve? if you do not have the light switch hooked up, check it with a multi-meter or simple test light hooked up between power and ground .
I'll check that tonight. What to do if it is tripped?
FarmMotorSports
Re: No rear brakes
https://www.ford-trucks.com/forums/1446 ... witch.html
This has pictures and some discussion about it.
There seems to be some debate on how to recenter... Or if it should just be replaced. .
If it will not recenter easily, then it may not work when you need it, seems to be the story.
61 F250 Unibody
