Just as an FYI, a machine shop will be doing all block work, so I will have the crank ground, everything planed, etc...
Where I need help is in a balance of performing reasonable upgrades vs. unnecessary ones. For example, is getting an RV cam worth it? I think yes but maybe someone has gotten one and it didn't make any difference worth while. The carb is a single barrel so is it worth upgrading that and the intake? I am not looking to make a race truck and it is paired with a 3 speed manual so highway speeds are impossible without winding the snot out of it. (Silly question, but how do I get a 4th gear!!!!)
The truck is a 65, but I am pretty sure the motor is from the early 80's. Any and all thoughts are welcome and appreciated.
Cylinder 1 crank bearing
Burnt Valve
