Brass threaded bushings should do what you need... You may be able to source them at the local flaps or even in the plumbing isle of a local hardware...
I have gone so far as to buy threaded brass pipe plug to fit the block, then drill an tap that to fit my sensor.
300 finally died. Motor is out.... what now?
- FarmMotorSports
Re: 300 finally died. Motor is out.... what now?
61 F250 Unibody
5.9 Ford Diesel / Allison
Disk brake straight axle
