What Slick60s Engine Transplants Have You Seen?
I've seen Coyote and Cummins swaps. How about a Triton V-10 or Perkins 6.354?
Re: What Slick60s Engine Transplants Have You Seen?
Haven't personally seen a 6.8 V-10 in a Slick, but I'd expect by now, someone has done it.
I do know a local fellow who's in the middle of doing the 6.8L swap on a Bumpside ('71 XLT), and being as his last swap was the Lincoln 4.6L DOHC 32V into a '57 Ford SW, I expect the Bump will be nicely done:)
- FarmMotorSports
A quick YouTube search "Perkins Ford" will net you several from South of the border...
I believe we had an Ecoboost build here at one time...
Mention of a Mercedes build but never heard of the results...
I've heard talk of a 'two stroke' Detroit in a Ford...
How about something rare, 427 overhead cam side oiler...
61 F250 Unibody
5.9 Ford Diesel / Allison
Disk brake straight axle
I'd seen Martin's Perkins powered Crew Cab but no Slick60s. The 5" stroke would get the load moving.FarmMotorSports wrote:A quick YouTube search "Perkins Ford" will net you several from South of the border...
- Johnny Canuck
The other Pat the farmer, slick 4x4 had a bump with a Detroit in it. Never saw it personally, but hear it was Cool and LOUD.
and of course there have been many many 350/350 combos in these trucks, sad as it makes me.
there are many, many good choices out there why waste your time on the lowest common denominator..
I put a Briggs & Stratton 3.5 h.p. in mine. It will pull a house down the road in that granny gear . . .
- 6166 Junkyard Dog
we just brought in 61 uni-bed Big back window short bed out of NM with 460 fuel injected in it air bagged 4-wheel disc BUT Hit real hard on Pass. side
Now Cooper will try his best
Are there quality headers for a 385 Series to Slick?6166 Junkyard Dog wrote:we just brought in 61 uni-bed Big back window short bed out of NM with 460 fuel injected in it air bagged 4-wheel disc BUT Hit real hard on Pass. side
- 6166 Junkyard Dog
Chris just peaking under the hood since it's raised up on pass. side it has stock exhaust manifolds rh side is pushed back a good foot if not more,, truck was insured by Hagerty, might have been a member truck here also ?
