Fenders?
Fenders?
Could anyone point me to any information on this site or anywhere else that will explain what fenders fit with what inner fenders. I run large tires on my truck and am thinking about changing from the smaller opening fender to the larger opening fenders.
I'm about 87.2% sure all the Slick fenders will interchange with each other, but I could be wrong, I suppose.
Just look for some 1-ton or 4x4 fenders & you should be set.
I just got a set of fenders off a 1-ton they look like they will fit just wasn't sure about the inner fenders. I looked at a truck with the larger opening fenders and the inner fenders looked different than what I have, they were more round in shaped than mine which are kind of flat or square in shape.
61-64 f100/f250
round inner fenders with notch for battery
61-66 f250 4x4, f350, f500
round inner fenders with no notch for battery, battery is under floor
65-66 f100/f250 & 66 f100 4x4
square/flat inner fenders with battery @ passenger front.
in your case if you only use the outer fender it will work, unbolt yours and put the new on. the bolt pattern is the same so you can put them on your inners.
