need help figuring out what I have
I'm needing a little help figuring out what I have as far as my transmission goes. It is a 4-speed and on the pass. side there is a small inspection cover or cover for a pto with these #s C6TA 7003 G F 19 and below these #s 2 7 66 435 it is in a little `63 shortbed unibody that has been put in a late 60's or early 70's 4x4 frame . it also has a married single speed transfer case spicer 21 is what the tag says. Any and all help is greatly appreciated, Chris
pipedobber wrote:Thanks for the information. Would you happen to know if I could use that same transmission with a np 205 provided that I also get the adapter plate , or would I have to change the output shaft on the transmission also. Thanks again for your help, Chris
that i do not know
