i bought a tci valve body, the old valve body had a pick up tube , but the new one didnt, and the hole is too small in the TCI valve body to just swap it over, does it need the pick up tube ?
________
Toyota TF103 history
question for c6 guys
thats just your filter. you can swap them over from the old valve body to the new one. I would definately want a filter with that tube over one without, esp if you have a deep sump pan. check with your local part store see if they have that same filter on hand or available, if not call TCI see if they have one
well the new aluminum deep oil pan had the enlarged filter and pickup extension, so all is good, is helpfull to know though if i ever had to do another one
________
Dodge Ram 50
________
Dodge Ram 50
