Trans cooler
Trans cooler
does anyone know if these type coolers perform any better than the standard coolers ? is a dual pass 24' long
________
FFM BLOWJOB
________
FFM BLOWJOB
blackagatha wrote:sure looks fancy, but I would say it probably wouldn't have anywhere near standard efficiency. There's not much surface area, compared to a radiator type, anyway.
I agree. Looks fancy. Surface area is what matters. If you cannot stand an accessorry cooler in front of the rad, then perhaps you could mount one of these somewhere, but otherwise, I would avoid it.
Re: Trans cooler
dwbr wrote:is a dual pass
Note that the exiting oil should not be anywhere close to the incoming oil. The incoming oil is HOT, the exiting oil we hope is cooler.
This design puts them right NEXT to each other, so that the heat from the incoming oil can pass over to the exiting oil.
NOT a brilliant design from a heat transfer standpoint.....
I used this type cooler on my 5.0 Uni. However it was the type that went in one end and out the other. I also put a dual remote spin on oil filter setup into the line to increase capacity and to facilitate changing the filters more often. All of this is mounted to the pass side frame rail. (need to get a pic) I want to put a temp gauge in and don't have alot of miles on the truck but all seems well----so far.
Tim
Tim
I run one of these on my 29 Ford and haven't had any problems with it here in Phoenix summers. I also have one that will be used on my 63 F100 when it gets done(almost ready for paint). The idea of these is that the aluminum fins will dissipate heat faster. I have always been told that it is still best to get them out to where it can get plenty of air flow but is not necessary.
Kevin
Kevin
kstones63
63 F100
29 Ford Sedan Delivery
99 F250 PSD, 4x4, CC
95 F350 Flatbed Dually Diesel
63 F100
Fanatic wrote:I used this type cooler on my 5.0 Uni. However it was the type that went in one end and out the other. I also put a dual remote spin on oil filter setup into the line to increase capacity and to facilitate changing the filters more often. All of this is mounted to the pass side frame rail. (need to get a pic) I want to put a temp gauge in and don't have alot of miles on the truck but all seems well----so far.
Tim
sounds like you got quite a setup going... DUAL remote filters? wow... might be a bit excessive, but it's better than roasting your tranny.
I dunno, it seems whatever sort of one of these you got, it should be getting BLASTED with air, and probably even then don't do much... It goes straight thru, and that thing even if aluminum (yeah, I know it has a better heat dissipation rate than steel, but probably about the same or close to brass) isn't gonna dissipate heat as well as a regular cooler, with fins about the thickness of paper....
I got my cooler set up wrong though... I recently re-plumbed my cooling system, and accidentally got the pressure and return switched up (well, I think so anyway). It wouldn't matter if I just had the little cooler, but I decided to run it thru the provision in the bottom of the radiator, to stabilize the temp I guess. Not really sure why exactly I even used that, really. I ought to just plug the holes up again and connect the line to the cooler and be done with it...
It's too bad there can't be some sort of thermostatic bypass valve... that would be cool. Like when It's like 25 degrees out, I don't really want to chill the fluid that much....
- banjopicker66
- Hoofbeat Racer
I never wanted to run lines to the rad so I mounted a B&M tranny cooler and electric fan assembly under my cab above the transmission. I used braided hydraulic lines and it works really slick, don't even know its there. Also mounted an electric tranny temp gauge by the console. Whole thing cost about 250 beans. Definately worth it if you're gonna put the tranny to the test.
Mark
well i bought a high dollar aluminum radiator with the oil cooler, but i am running a 2800 stall on my tourque converter and was told i would need more cooling than what the radiator would support, so i am just trying to figure out the best approach, i was thinking of running the one pictured in front of the radiator in that flat area behind the grill, dont know if it would look funny or not, plan to have the fluid go through the radiator first, then through the cooler that would be infront of the radiator... i also thought about installing a temp guage and just see what it runs before i add the additional cooler
________
Mercury Colony Park specifications
________
dwbr wrote:well i bought a high dollar aluminum radiator with the oil cooler, but i am running a 2800 stall on my tourque converter and was told i would need more cooling than what the radiator would support, so i am just trying to figure out the best approach, i was thinking of running the one pictured in front of the radiator in that flat area behind the grill, dont know if it would look funny or not, plan to have the fluid go through the radiator first, then through the cooler that would be infront of the radiator... i also thought about installing a temp guage and just see what it runs before i add the additional cooler
that's pretty much what I got goin on... looks fine. routed the hoses to it thru a stamped oval hole in the core support.
- Alan Mclennan
The trans cooler that dwbr asked about is a heat sink type cooler which is very effective, the same principle is used widely in the electronics field.
I seem to remember that they have to be mounted parallel with the vehicle and better with a breeze crossing the fins.
dual pass ,if it doesnt work why would you make them, take it easy on me for that statement thou .
does that model have the in line filters!
Alan,
Alan,
- Truckfarmer
I have one of those that I plan to mount to the outside of the frame. I am using the cooler that is built into the radiator and am going to plumb this into the return side. I am going to cut about 10'' from it and use that for my power steering.
I have to agree with cdherman, the outlet should not be next to the inlet. The oil you just cooled is going to be heated by the incoming oil. The local hot rod shop built a 57 Belair and they used 2 of the dual pass coolers in tandem in front of the radiator. It looked very high-tech and probably helped with the problem of heating the oil again. Gives a new look when you hardline it with polished stainless steel tubes.
FYI, to get these at a discount, look at the same catalogs that short track stock car racers use. Years ago, you could buy a 48" single pass unit for $39 in their catalogs. Due to the demographics, a 18" or 24" unit is $89 in the street rod books. They were priced according to their customer's willingness to spend money. Also the fact that the dirt track boys use these should be proof that they are very stout.
- Uncle Skip
DW.
I got one kind of like that mounted under the front bumper.
On mine, its downstream from the radiator cooler so it does drop the temp quite a bit.
Remember, its Texas, its stop and go traffic, its drag racing, and other crap, and those other things tend to heat up the transmission more than usual.
Anyway, effecient or not, I'm happy with it, and it does look kind of cool tucked up under the front of the frame.
People do notice it .
Just my dos centavos worth.
Tio Skip
Tio Skip
