Tires And Wheels... Argh!!
Ok, so I'm in a dilemma...
I need tires for the '66 and I'm unsure of the size that's gonna fit/look best. Right now I'm looking at some Yokohama Geolander HT in a 265/70/15. But I don't know if they'll be too big.
I've been doing some searches and some reading on here, but if anyone has any specific side shots of their truck, could you post it please and tell me what size tires you're running?
Also on what kinda wheels and backspacing.
I'm wanting the Chrome Smoothies, but I can't seem to find it in anything less than a 4" backspace and I don't know if that's gonna be TOO tucked under the rear. I just like for the wheel/tire to fill the fenderwell without looking too dinky.
Is anybody running two different sized tires on different backspaced wheels - front/rear? I don't want to do this because of rotating the tires, BUT if that's what it takes to look "even" I'll have to. I noticed last night while trying on some 15x8s [4" backspace] that the front tires looked fine in the fenderwell, but the rears were kinda skinny and too "tucked under" for my tastes. I don't want to spend a buncha money just to sit back and say "that other size would have looked better, ya know?
Anyhow, pics with sizes would be great. Thanks.
[The one thread I did fine, was pics of HeavyHaulers Uni, but couldn't find what size the tires were.]
i have 275/60/15 with 4.5 in backspacing on the rear, 235 60/15 on the front, not sure on backspacing, but looks about the same, is a little bit too much on the front, have a hard time with the width on trailers since the front is wider.. new rims will be narrower for front next time
________
Cultus
________
Cultus
I was able to get 31x10.50s up into the back of my 64 & my 66 short with the stock springs & a styleside box (you need a REAL big jack or a frame lift though). That size shouldn't be any issue. Only thing you might want to think about is narrow is better on the front if you don't have power steering. I presently have 235x75s on the Uni and wish the fronts were narrower so it would steer easier.
- Alan Mclennan
G`day effie, Lenore has on the front 17x7 rims with 4" b/s,bridgestone dueler H/P 255-60r 17 rolling height 29",
on the back 17x8 rims 4.5 b/s should`ve been 3.5! bridgestone dueler H/P 275-55r 17 rolling height 29"
Alan,
Alan,
- bobenhotep
i have probably the smallest tires anyone has on a slick here. i have 215/75r15 on all four. made sure to get them in a high load/ high psi rating. my 10 year old can turn the wheels on flat ground while the truck is sitting still. it is effortless if moving at all. no clearance issues. the taller the tires are the harder your brakes have to work...
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
"The Iron Rhino"
-duraspark II/ HEI
- dotcentral
Effie, I just put those same Yokohamas Geo H/T (23570R16's) on my Jeep Liberty. Got them from Discount Tire, if you have one of those. There is an instant $50 rebate, plus they knock off about another $30 as well.
These tires have good reviews on Tirerack.com
dotcentral wrote:Effie, I just put those same Yokohamas Geo H/T (23570R16's) on my Jeep Liberty. Got them from Discount Tire, if you have one of those. There is an instant $50 rebate, plus they knock off about another $30 as well.
I have the Yoko Geolander ATs on my Bronco and thats what kinda lead me in the direction of the HTs. [Never run a Yoko before and really like the ATs so far on my Bronco.]
I have a Discount Tire, too...its where I got my ATs and he even haggled the price with me. I told him I priced them somewhere else for a lesser price and he come down to what I was willing to spend. I didn't tell him the price I got the first time was a dealership employee discount.
Well, I went down to Summit today to buy some other goodies and went ahead and bought the Smoothies in 15x8 with a 4" backspace. The wheels on it now look good in the front [as far as wheel placement is concerned] and my brother said if with the new tires they are too tucked [in the rear] it's not problem to add like a 1/4" spacer plate behind the wheel.
Maybe ya'll can answer this...what is the trick to getting that smoothie hubcap off without damaging it? Is there a special tool or something? We stuck the wheels on there and popped the cap on just to check fit and look...then had to figure out how to get the cap back off. Small screwdriver wrapped in a rag worked, but I'm sure there's a better way.
Thanks for all the replies. Ya'll brought up a good point about the steering. I think now I'm leaning towards a 245/70 or 75. I don't have PS and no plans of now to convert...I like the armstrong steering, reminds me I'm driving a real truck.
- ezernut9mm
that's what i use. a small screwdriver wrapped in a rag. be careful. those centers dent really easy.
gettin' smoothie caps off
Effie, I have been thru the same thing trying to get those caps off. Like they said, they dent pretty easy.
If you have a brake spoon laying around, you can wrap some tape around it and pry them off with it. The curved ends on these work real
well for this, and you can carry them around in your glovebox. I have even rolled up a shop rag and put it under the curved part to protect the wheel (mine are painted) so it wouldn't scratch the paint. I run the stainless steel pop on caps on the old style "innie" wheels. I also have some chrome smoothies like yours and found this little tool always works well to get 'em off. TR
- mrcando_66F100
Any competent wheel shop should have a tool similar to this one click here
Or you can use this page to do it yourself.
I hate Message Boards.
Rosati wrote:Any competent wheel shop should have a tool similar to this one click here
i bought one of those and they suck, it is almost imposible to use that "tire size" wire crap
________
hemp
frank66 wrote:I don't know off hand, but I might be able to measure one for you sometime this weekend. I didn't specify back spacing when I ordered them, I just told the guy what truck they were going on.
Effie wrote:Do you know the backspacing on those wheels?
I have the same rims, and did the same thing as Frank. I have one off right now, I will try to get out tomarrow to measure.
