the carb has a 2bbl carb with a spark control valve like on a 223 carb.
[albumimg]3136[/albumimg]
what is this???
- bobenhotep
what is this???
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
"The Iron Rhino"
-duraspark II/ HEI
- FORDBOYpete
It appears to be a 1955 272 CID "Y Block" 2V, Intake Manifold with seemingly a Ford carb that replaced a old # 54 Stromberg they used on 1954, 239CID "Y Blocks".
The thing on the side is not a spark control, it is a "Dash Pot' generally used with Fordomatic A/Ts to prevent slaming on a down shift if/when the throttle was lifted too fast. . . . .
FBp
FBp
Change is the Only Constant
- bobenhotep
the thing in the middle of the picture sure does look like a spark valve.
[albumimg]3142[/albumimg]
"The Iron Rhino"
-duraspark II/ HEI
"The Iron Rhino"
-duraspark II/ HEI
