blown head gasket
- ethan_lanning
blown head gasket
does any on know if the liquid stuff that you pour into the motor works?
or is there something you can recomend other than changing the head gasket?
Never poke another mans rust bubble.
http://www.supermotors.net/vehicles/reg ... 6959/57442
I'm only 1/100th of the gear head most of the guys on here are, but something as serious as a blown head gasket, I would be inclined to bite the bullet and change the gasket ASAP!
Gene
1961 Intregal cab SWB 223 (getting 302 & TIB)
1969 LWB 302 automatic (Donor for the '61)
2000 F150 XLT SWB (Daily Driver)
Barr's Leak makes a product that's suppost to be good for a blown head gasket, BUT I would never go that way. If this is a vechical your going to keep I would recommend replacing the gasket.
Donnie
2011 F150
32 Ford Coupe
1985 Mustang 10.50's 1/4
1997 F350
If it wasn't on 8 Track it's not worth listning too
2011 F150
32 Ford Coupe
1997 F350
- ethan_lanning
well as much as I hate to say it I will probably go ahead and just change the head gasket.
.thanks for your opinions.
FWIW there are many problems that are a lot worse than a blown HG. IT's just all the crap that you have to remove that is so bad - But it's still better than the new stuff (modern engines), right?
They are cheap, and as long as you have a good torque wrench you know you can knock it out in an afternoon - just don't drink so much beer that you forget to re-install something or put something in backwards (much easier to do than it sounds, right?).
Hopefully everything underneath is still tit when you get there. . .oh my memories of those moments of horrid realization when you see a piston with a crack or some god-awful scar down the side of a cylinder wall.
Good luck!
Good luck!
My new signature.
I've gotta go with Garbz on the Bars leak thing...that stuff's only good for plugging up your radiator, heater core & leaving mystery sludge in the bottom of your block.
Aluma seal ain't much better.
I've never been a fan of any of the 'mechanic in a can' crap. You'll be better in the long run by doing what you're doing & fixing it the right way.
I have used what my Father called "Water Glass", sodium silacate, not sure of the spelling. You get it a the pharmacy. My Father-in-law got away using it on a 91 Areostar for @ 50,000 miles. I used it in demo cars, but I would not use it for a truck for the long term. With a head gasket it is aways best to fix it, but sometimes ya just have to get them home.
1966 F-100 4x4 390hipro
1964 Galaxie 428 ci
1967 F-100
1968 F-350 crew truck
1964 Galaxie 428 ci
1967 F-100
There is some stuff out there called Block Sealer. You have to flush the system pour the stuff in with water and run it to temperature. Drain the system, let it dry over night. Reflush the system, refill with antifreeze. After all that crap it is still a temporary bandaid at best.
Change the head gasket, partially because you will want to check for any further damage while you are in there. I have seen the coolant spray cut a groove in a block after a gasket let go. Not trying to borrow you more trouble though.
- 6166 Junkyard Dog
some of these ideas sound good but not only might stop the leak but also stop up the heater core as well,, have seen many heater cores stopped up....
Now Cooper will try his best
