whiat weight oil do I use for open 9 inch rear?
cosmo
Post by cosmo »
Im doing a frame off resto on my 1966 F-100 and now is the perfect time to refill the rear axle with some new oil, but the owners manual does not specify the weight
First off, I did check some past posts and I belive I have an open rear, There is no "L" on the tag and I can spin one rear wheel while the other stays still.
So I'm hopping that enough evidence that I dont have a limited slip. I down wasn to screw up with the additive, if I dont need it
Any advice would be appreciated
Garbz
Post by Garbz »
Use 90 weight gear lube. Or a modern 80 to 110 blend synthetic or semi synthetic. Beats the crap out of the Sperm Whale oil it had in it originally.
No nine inch rear limited slips were offered in 61 to 66 ford trucks.
If you wanted a LS differential you got the DANA.
Garbz
Slick Fan
Post by Slick Fan »
cosmo
where's the vent
Post by cosmo »
the 9" rear on my mustang has a vent tube, but there is none on the truck, or at least I cant seem to find one....any ideas?
Garbz
Post by Garbz »
The vent tube is the bolt that attached the brake lines.....
Garbz
oldtrucks
Post by oldtrucks »
Any one
I have a dana 44 3.92 gear ratio limited slip from a 61 uni if any one is interested. Needs rebuilt end to end though
Mike Kincheloe
