OK, I think I have posted this before, but here goes again.
I have a 71 PS column that is the shorter variety (works with later Ford/Saginaw box). I have drilled the spot welds out of it to remove the bracket that holds it under the dash.
I have the correct bracket for my 65 (this bracket is specific for 65-66, though the rest of the manual steering and 65-68 PS columns are interchageable).
I would like to weld the earlier bracket to the later column.
I'd rather not assemble the whole thing to verify things (long story why).
Can I just weld the earlier bracket on the same spot as the later bracket and be done with it?
Does anyone who has done this swap know if the bracket location changed much?
Thanks fellas......
Power steering upgrade question, 65-66, ??
- jkimbrel65
- Truckfarmer
Truckfarmer wrote:If you are worried, slot the holes so there is adjustment, top to bottom. A washer would cover it. Better now than after paint.
Ford already slotted them, but I noticed that my donor bracket had been bolted at the far end of the slot. This is what got me thinking that I might get unlucky and find that when I have it assembled, there is a 1/4" still left between then steering wheel and upper "hub" and it will look like crap and the turn signal won't work.
Ford obviously slotted them for this reason. Since there is a little natural variation in the cab mounts and rubber pucks, even if they are not rusted, I can see the slots being there from the factory.
Well, if its exactly the same, then I may just take a chance. Problem is that once I have wleded it, it will be a real pain to move it if I am wrong..... Spot welds drill out nice, but a MIG will be a little more permanent.
FarmTrk wrote:I did the power stseering swap also, althougjh I used the other steering box. I did just what you descried, took the bracket from the old column and welded it onto the new one. I didn't have any problems with it.
How did you decide where to weld it? Did you dry fit everything, or just match up the old and new locations and weld it?
