Santa was kind enough to bring me 2 TWIN I BEAM emblem inserts.
What is the best way to remove and replace the old ones from the fender without doing any damage? Thanks.
66 Twin I Beam Emblem Removal ?
- banjopicker66
- DV65CustomCab
The plastic ones are a bit tricky to deal with. The chrome parts are pot metal, which is not very forgiving. The plastic is held in by little tabs on the backside that I didn't have any success in dealing with (meaning, they break easily). My solution was to use JB Weld in small globs at several points around the perimeter of the insert to hold it in place. Let dry thoroughly before reinstalling. Try to keep the epoxy from the visible part of the insert as they are a bit transparent and it may show through as a shadow. I've had mine in that way for a couple years now with no problems.
Removing the chrome bit from the fender is done as described above. Plastic spatula to start, then keep it under the blade of a screwdriver to pry the edges up and the whole thing off.
Stop The Longbed Hate!
Now: '93 F150 Lightning
