too many wires
moonpie
too many wires
Post by moonpie »
here we go with more steering column woes. tilt column from a 78-9 bronco has way more wires than i can possibly use. any guidance towards a diagram that might help would be appreciated. it,s going in a 66
Kevin
[albumimg]3095[/albumimg]
Post by Gritsngumbo »
How's the install working out other than the wiring issue? I really would like a tilt column for my 64 but the options seem limited (Note: column will be cut for a R&P setup, I'm not trying to hook column up to 64 box) just curious as to fit, brackets etc.
ras4434
Post by ras4434 »
Moonpie: If no one is able to help later this evening I can get the number of guy I use to fab most of my parts. His business is working on the older broncos. He is GREAT and knows them inside out. I will watch the board and if nothing comes I should have his number this evening late.
Johnny Canuck
Post by Johnny Canuck »
Moonpie. try this great article from the fine folks over at Fordification. Our wiring, especially for a 66 is durn close to what a bump has.
http://www.fordification.com/tilt.htm
Garbz
Post by Garbz »
Grits
I have an 88 ford tilt from a F250 in my 64...
Attached to the stock box.
There is a pic or two in my gallery.
Garbz
moonpie
Post by moonpie »
that's pretty good information johnny THANKS. i just pulled the bronco column yesterday so i'm just trying to get my ducks in a row before i start on the install. going to wait until after f100 supernats next week, because i can drive it right now but, if i tore into it today i'd probably be driving something else to the show.
Kevin
