ezernuts 66 swb "build"
ezernut9mm
Sweden
Post by ezernut9mm »
i already posted this in the truck talk forum, but what the hey!
it's a 66 short styleside. originally 352/com.
it's getting disc brakes off a 73 f100. out with the old:
i'll get pics of the install when i get to the other side this weekend. it's supposed to be in the 40's, so maybe i'll get some work done.
BackyardRest
Post by BackyardRest »
Please keep us updated on your progress.
What engine is going in the slick? From pics appears and FE of sorts..
ezernut9mm
Sweden
it'll be an fe. i just have to find the right one. ;)
ezernut9mm
Sweden
got the brake hoses on today and started bleeding the brakes so i can get it moved to the driveway to swap in the 360, but the master cylinder is leaking into the cab. looks like i need to get a dual pot for disc/drums.
anyone know a good place to get a proporsioning valve for a 73 up truck? lmc wants 250$.
anyone know if i can use a dual pot drum/drum mc and plug the rear hole just to get enough brakes to get up into the driveway?
65 66 Ford
Post by 65 66 Ford »
This is the least expensive one that I have seen for new.
http://cgi.ebay.com/ebaymotors/Parts-Ac ... 240%3A1318
Fran
65 Ford F100 CC style side looooongbedddddd
Be American buy American
ezernut9mm
Sweden
hey, thanks for the link fran!
Fanatic
Post by Fanatic »
Chris ....why not just use a factory one. Unless you are doing something way out with the brakes. You can even hook up the light to let you know of uneven pressure( blown line)
Tim
ezernut9mm
Sweden
tim, the factory p/valves are 250 from lmc. i haven't priced one from the local parts house yet, but i can't find one on thier websites.
i understand that i need the disc/drum p/v and not the original metering block that the 66 uses. correct?
That's correct!, I don`t know why people say your dumb Agarn! :lol: and remember to pull the little tit on the front of the P/valve while bleeding the brakes..
ezernut9mm
Sweden
ezernut9mm wrote:tim, the factory p/valves are 250 from lmc. i haven't priced one from the local parts house yet, but i can't find one on thier websites.
ezernut9mm
Sweden
got the seat out and cut out the hump for the removable piece.
trying to figure out what this was supposed to be for???
my swap meet grille and h/l doors:
free cc handle trim. it's ugly, but so is the rest of the truck:
anyone have any idea what the shifter is out of? it has the matching turn signal lever as well:
that's it until i can get a nice weekend to work.
just about where E-brake handle is on some trucks....
same spot as a 4x4 lever...except on pass. side instead of drivers..
slick4x4 wrote:trying to figure out what this was supposed to be for???
seen lots of those, never have figured out what they are there for.
Confusulator bracket.
rbcyouthdude
Post by rbcyouthdude »
Why did you cut out the center section? Are you putting a diffrent transmission?
Just curious.
michael
ezernut9mm
Sweden
yes. it will be getting a t-18 4sp.
ezernut9mm wrote: trying to figure out what this was supposed to be for???
Image.
That particular hole is there for when the very rare Vert model is ordered,so when it gets too hot! or if it rains!, you can stand the umbrella in it!, simple!!! :wink: Now Chris that little pic of you with the pistolo, it looks like you have been back to our favourite HOOTERS more than once since SS3 :P
ezernut9mm
Sweden
lol @ alan. i love hooters. food and service sucks, but i go for the beer and b@@bs.
DCarr
Post by DCarr »
Chris, it must be a bullet hole patch. :rotflmao:
ezernut9mm
Sweden
DCarr wrote:Chris, it must be a bullet hole patch. :rotflmao:
oh no. those are very distinctive. it's the chunk of indoor/outdoor carpet and heater hose that sets those off.
