Beryl`s re-build
Alan, you must hold the camera with the lens facing the other way.
Here ya go buddy........................................
- Alan Mclennan
WOW Tim!, yours looks just like mine!
- Alan Mclennan
starting to think about taking the cab off!, and sitting in the drivers seat( as we all do , don't lie!! ), I was thinking what can go and what needs to stay and I started to count the extraneous holes in the dash, how many do you reckon there are?, count the match heads!, oh and add one for the radio
[img][img]http://i533.photobucket.com/albums/ee337/maccas66/DSCF0062.jpg[/img][/img]
Alan,
I filled all the holes in my dash that will be seen. It was a lot of work but worth it.
I also made some new defroster ducts for mine as they crumbled when I took them out.
Keep up the good work.
Kevin
Kevin
kstones63
63 F100
29 Ford Sedan Delivery
99 F250 PSD, 4x4, CC
95 F350 Flatbed Dually Diesel
63 F100
- Alan Mclennan
Looking good Kevin, you certainly put some time into that dash, and it has paid off!, you noticed the defrost jam tin things?, what a joke they are!, yours are well made, what did you make them out of, other than Aluminium, they look like a kamlock fitting!. one more quiz, what are the seats out of?
Alan,
I made the defrost ducts out of a round piece of aluminum. I bored them on the mill and then turned them down on the lathe. I put the lip on the bottom so that I can put a clamp or zip ties around the hose to keep it from slipping off. $20 worth of aluminum and about 6 hours of not knowing what I ws doing to get them done.
The seats came out of an 01 F-150 4 door. I am going to cut down the headrests about 3-4". I think they take up to much room in the back window(kind of redneckish ) I will make the decision where to cut them when I get the upholstery off.
Kevin
Kevin
kstones63
63 F100
63 F100
- Alan Mclennan
Kevin,
the seats look great!, not many 2000 and on F150`s out here, I had a slick seat recovered but it is still a 1966 seat!, and Beryl is going to be a daily driver with most days 1hr each way!, I have 02 Cherokee seats in Lenore and have the same problem with the head rests taking up leg room, your column and wheel look sweet as well, are they after market?
- Hoofbeat Racer
- Hoofbeat Racer
That looks Real Good Alan! Looks like those headers fit real well too.
- Alan Mclennan
Mark, 15 2, and a pair is 4
Tom, plus the radio hole! and Dav hang in there mate!
is it safe to go in off subject yet?
Kevin, there would likely be a market here for more of those defrost vents if you wanted to make them - just a thought.
- Alan Mclennan
Dave, the panel beater has a brass mig that uses lower heat, we`ll probably use that!, or I could hook the air-con up to them and use them for air vents!
