I started by applying a peel and seal type sound deadener to the floor, roof, area below rear window. Followed by a foil backed heat/sounddeadening insulation under the carpet & in the door panels & above headliner.
Not sure what I did wrong but I really didnt notice much of a difference at all. The product I used was not the Dynamat brand name, but after alot of research it seemed like there are a ton of products out there that are just as effective without the extreme pricetag, so I went for a middle of the road brand.
The main difference I do notice is when I shut the doors they sound solid. But highway drone remains basically the same & idling in traffic has slightly improved. I will add that my weatherstripping isnt the best, its not original, but it appears the PO used a cheaper quality that doesnt seal as well as I think it should. Nonetheless, I am a little disappointed and not sure what I might have done wrong, do any of you guys have slicks that have a quiet ride due to proper sound deadening?
